My way is to think about the threads having equal pitch. Say we adjust the valves with a screw tappet and not shims. If I ran the screw out 1/4 turn, might the others wind up close to the same number we start from zero? So if I held the adjuster nut, ran the adjuster screw up under a dial indicator, moved that a full 360° turn, wouldn't that show about the same numbers we swap adjuster screw and nut?
So how about we run the adjuster bolt into the swingarm; have the lock nut hand tight up to the head of the bolt; turn the bolt so it bottoms out; from there is to match the other side with a measuring device; paint one flat of the bolt head so we find a 360 degree turn of the bolt. We now count each flat as they take up slack real fast!
That said: I will be dragging the axle and blocks rearward. That too says: I loaded the threads on the bolts to swingarm gaps. There are no other moving parts floating, but to match the block's indent with the swing's adjuster line up marks.
For accuracy of the indents in question, I'd line up the V blocks so the indents face each other. I set them on a table so both are equal at the bottom, the V up in the air. I look at the indents and how far [up or down] are they from each other? That's how I'd question the blocks. I would assume the swingarm is accurate when it started out as a 2-dimentional drawing with equal sides to create the 3rd dimension being the swingarm itself.
1. Flat for flat says float my axle to the bitter end.
2. Step on the chain rung I have my flats equal and the axle is going to keep things squared.
3. Torque to spec or if I know my 92 pounds wound up here, then I painted my axle so it is always this side up; my hole for the cotter is painted and is in the up position I miss with the axle insert. The nut has a paint mark and if 92 pounds lines up that nut slot to the cotter hole in the axle, that's one more no brainer [torque] tool I need to adjust chain/change tire/new wheels/etc with a box end wrench or socket setup.
* Last updated by: Hub on 2/27/2015 @ 9:59 AM *
