&TIDJust did some forum research. EBC HH pads are often recommended. Complaints about the pads do not seem common. Mostly positive statements of decreased stopping distance. I read a couple comments about noise from the pads apparently caused by open spaces in the back plate that reduce heat transfer. One suggestion from a trusted source (in the one of the links below)of applying a cream available at Autozone before installing to eliminate the noise. Also read a review where the owner felt the pads were not as good as OEM or had weaker initial bight until the pads warmed up. He felt that the pads caused fading after a few hard applications in sport riding. Less noise when cold.
EBC has a heat dissipating backplate to the pad which reduces the heat transferred to the brake fluid and reduces fade from fluid overheating. Also the composition of the pads is supposed to have more good stuff and less bad ingredients than than competing pads. The composition has been perfected one time since the pads were introduced.
OEM pads also highly recommended for the 14. Found this review rather surprizing. Note the las comment about resurfacing rotors when switching pads.
Another review not entirely positive but seems like most of the responses are in support of the HH pads.
Here are where I found good prices for front and back.
REAR $30 free ship
FRONT <<$90 Need to order another $10 of stuff to qualify for free ship on this one.
OR just order front/back here --do both front and the back for a couple bucks more.
FRONT AND REAR $128.45 free ship
REMEMBER>>>>YOU NORMALLY MUST ORDER TWO UNITS TO DO THE FRONT BRAKES UNLESS IT IS A PACKAGE DEAL -- 1 UNIT IS TWO PADS WHICH WILL EQUIP ONLY ONE CALIPER
Before I even try these pads, I have to make the observation that the stock brake system will easily lock the front and back brake even at ~60 mph with a 200 lb rider. I don't know how much stopping distance would be increased by any upgrade. Maybe necessary if you are a very large man or carry a passenger? ABS would be the only thing I can see that could decrease stopping distance for everyone in all situations.
* Last updated by: Rook on 6/29/2011 @ 12:57 PM *
08 MIDNIGHT SAPPHIRE BLUE ZX-14 Now Deceased, will be resurected
2024 ZX-14R bran friggin NEW!
