Thread: Sprocket hub removal?
Created on: 02/18/14 08:25 PM
Cornelius
Cornelius's Gravatar
02/18/14 8:25 PM
I have a quick stupid question. I sold some rims recently and the dude just asked me if it was supposed to be hard to remove the sprocket hub. I don't have a good answer for the dude cause I've never had a reason to pull the the hub off so I have no idea how tight it is in there. Can anybody help with an answer?
Cornelius
RE: Sprocket hub removal?
02/18/14 8:30 PM
Its a stock zx14 rim btw.
02/18/14 10:44 PM
Is this what you mean?
http://www.procaliber.com/oemparts/a/kaw/50aa38d0f8700226a414676c/rear-wheel-chain
Hold 41073 on the ground with your knees.
Pull 42033 straight up in a crisscross pulling position. Install sprocket to make it easier to yank on out of there.
02/19/14 3:54 AM
You mean the coupling? mine came off by accident. I was lowering the wheel down onto a tire changer holding it by the sprocket and the coupling pulled out under the weight of the wheel. I have held the wheel in this fashion a few times before while placing it down into the trunk of my car and it did not come off. Maybe it took a while for the coupling to loosen up. Obviously this is not a safe way to hold the rim but it does pull right out without needing to remove any fasteners after taking the wheel off the bike.
* Last updated by: Rook on 2/19/2014 @ 3:58 AM *
Cornelius
02/19/14 4:43 AM
42033 coupling assembly.
Cornelius
02/19/14 4:45 AM
Sounds good thanks guys. I kept the sprocket so he has nothing to pry on the assembly with and I think that's half his problem.
02/19/14 7:33 AM
that seems like that would do it. I bet if he puts a new sprocket on there and wiggles it a little while pulling as Hub described above, it will come right out.
02/21/14 3:29 PM
A little resistance if the cush is in good shape, no resistance, replace the cush.
maverick1441
maverick1441's Gravatar
02/26/14 7:54 PM
I'm sure you guys know but don't lose the spacer that is located behind the cush drive!
02/27/14 3:24 AM
^^you mean that metal short beveled piece between the coupling cover and the wheel bearing...I think the Book calls it the coupling collar.
I have a How To coming on that but first I need to get my tire replacement How To done.
* Last updated by: Rook on 2/27/2014 @ 3:25 AM *
