Bought a new air filter cover-$16.00-2008/2009 model.Made of metal instead of plastic.No more Warps.Kawasaki part #11065-0220.Called a "cap".Will fit 06's-09's.
* Last updated by: blue07 on 8/1/2009 @ 1:38 PM *
Created on: 08/01/09 01:35 PM
Philhnnss
RE: air filter
08/06/09 7:04 AM
Yea, don't buy this billet one like I did. It was almost $50 with shipping and the o-ring seal wouldn't seal properly. Had to glue foam weather stripping tape to it. It is stout though and won't warp but it must weigh a half pound.
kawnow
RE: air filter
08/07/09 8:01 AM
Thats the first step to a turbo set up on your bike. Better keep going, another 4500 dollars and your done.
LOL! Seriously though, I wrote the owner of the company on this. The cover is beautifully machined from billet aluminum and the o-ring seal is elegant, it's a precision made work of art. Problem is, the area of the frame where it seals to is not a precision machined surface required for the o-ring to seal properly. It is a gravity cast section and the surface finish is rough and wavy as I confirmed with a straight edge. You need a thick chunk of foam ruber, 3/8" minimum to seal here. Sometimes Lo-tech is the way to go.
* Last updated by: Kruz on 8/7/2009 @ 8:07 AM *
