Thread: All 4 headlights out!
Created on: 10/25/16 08:33 AM
ApogeeNow
ApogeeNow's Gravatar
10/25/16 8:33 AM
I can use some help; all 4 headlights stopped working.
They're HIDs, that I had installed about 7 years ago,
but I can't see all four bulbs and/or all
four ballasts going all at the same time. That doesn't make sense.
I checked all of the fuses, first visually, then physically,
they are all intact.
All other lights are working, blinkers, tail, brake, etc.
The battery is good, as is the charging system.
The bike is a 2007, with 38k miles and garage kept.
Does anyone have any idea as to what may be the problem?
2007 Plasma Blue ZX-1464, 2mm Bore X 2mm Stroke (1464ccs), OER Hi-Mounted Full Exhaust System, Re-Flash, KN Air Filter, SpeedoHealer, Flies Out, FP Velocity Stacks, Under-Cut Gears, HotBodies Undertail, ZX14 Chain Guard, Cox Racing Radiator Guard, 600 amp Antigravity battery, Auxiliary cooling fan, HID Lights 6K-Lo / 8K Hi, Valentine Radar Detector
RE: All 4 headlights out!
10/25/16 8:59 AM
Check headlight relays?
Headlights don't get power until engine starts to run.
