I was told by Delkelvic their slip-on's will retain the Cat but wouldn't that only be true of the Gen 1 where the cats are in the header? She said it would be really loud if the cat came out with the stock pipe.
Created on: 10/23/15 12:38 PM
Auron
Auron
RE: Cat question
10/23/15 5:29 PM
I believe slips are a straight shot out, so yes, loud is the hp game. Baffles may have a slot for it, but no broomstick is going to stop mid-pipe? My slips were too loud around the neighborhood so I mickey moused snuff'or'nots at the rears.
RE: Cat question
10/24/15 6:14 PM
I'm fixated on the computer's physical moves, if not every move. I was reading about 'coincident-current,' RAM and ROM, ferrite core to name a few parts and functions. I go online and looked up the physical 'ferrite core' as an image. You are looking at 'write wires' and 'read wires' passing thru that core. So the theory goes... Store an 0, a magnetic field circles clockwise around that ring; Write a 1 it goes ccw; X and Y directions at 4 corners more or less. A sense wire finds the path of open gates going in one direction. So this is more of a path for written RAM and ROM.
This is the memory core area.
http://ed-thelen.org/comp-hist/Byte/76jul.html
untamed
RE: Cat question
10/25/15 10:05 AM
2012-2015 = Cats in mufflers only.
toledoUPSguy
