Thread: unitrak protection
Created on: 08/03/09 03:08 PM
unitrak protection
08/03/09 3:08 PM
I removed my bottom fairing today. I noticed there was not a mark on my unitrak or rocker arms. Anyone running without the crud catcher notice any chipping or pitting on their unitrak from stuff bouncing off the road?
Donny
Donny's Gravatar
RE: unitrak protection
08/04/09 11:05 AM
I pulled mine off a year ago, no noticeable increase in crud, just that it's far easier to clean the linkage with the tray removed.
www.drblast.com
08/04/09 12:13 PM
Thanks, Donny. It does trim up the appearance of the bike and shed about 11-12 oz to remove it. I like the way the 14 looks both w & w/o the lower fairing so I'll probably switch back and forth.
kawnow
kawnow's Gravatar
08/05/09 12:51 AM
Took my crud catcher off and put a center stand on a while back. I like the center stand, don't care if it adds weight. Best way to clean the linkeage the couple times I've done it is that citris cleaner stuff. Haven't noticed any damage to the linkeage more concerned about the radiator but haven't protected it yet either.
08/05/09 4:59 AM
At 10,000 miles, I am starting to see a couple bent radiator fins. They seem to be right behind the front tire. At the rate it is happenning, I doubt the slight damage will affect cooling much for another 20,000 miles. Still not a bad idea to put a gaurd on there.
Donny had a good DIY radiator protector thread on the old forum. You should put that one up here, Don.
