Thread: bleed clutch
Created on: 08/03/09 08:56 PM
rvents
bleed clutch
08/03/09 8:56 PM
Can someone help me on how to bleed the clutch? The more detailed, the better. Thanks
RE: bleed clutch
08/04/09 12:45 PM
I have to do the brakes and clutch fluids some time too. I'd wait for Hub to get his video up so you can see the exact location of bleed valves and such. In the mean time, this might give you a little info.
xxxses
xxxses's Gravatar
RE: bleed clutch
08/05/09 10:53 AM
I use to do it the old school way as you reasonable sure you get all the air out
but now they have theese for about 60.00 bucks seeams pricey but It will only take you 2min per side and back and for the clutch what this tool does is sucks the fluid thruogh the systemand all air with it while depositing the waste fluid into the waste resevior and all you have to to is squeese the handle and add fluid to your clean fluid res. Dont have to mess with banjos or even pump the break or clutch one time you can if you feel you should but it will do the job all by it self with little effort on your part and the part I love the best is NO helper "DID YOU SAY HOLD" NO NO PUMP lol you get what i mean good luck...xxx's
RE: bleed clutch
08/05/09 8:28 PM
^^Advance Auto will let you use a very similar tool when you put down a 100% refundable deposit. Probably $40 and you get it all back. Might be worth checking out.
xxxses
xxxses's Gravatar
RE: bleed clutch
08/06/09 10:38 AM
lol hub you sure are funny the hose you see (long one in the pic is just stock) that I had in storage with the tool you use about 3 to 5 inches and dont be afraid times are ah change n so this is something you can use and no 1 need know
xxxses
xxxses's Gravatar
RE: bleed clutch
08/06/09 10:40 AM
xxxses
xxxses's Gravatar
RE: bleed clutch
08/06/09 12:50 PM
ok hub I see that at least you when you've been asleep and dreaming lol
I love a good OLD fashion challenge I just wish we lived closer together I'm on here sometimes longer than I think I am hince the xxx's in my eyes when I read your post I was laughing and when I wrote mine as well keep um comming hub this place is more than just an info highway I love the laughs and the BS ...xxx's
