Well...the 14R is away for the winter. I was going to tackle the plugs, but after getting to the point of pulling coils....I noticed the Idle Control valve sitting there. I unscrewed it off the frame mount. I found if you pull it down so that the large intake hose that goes in the air box has a lot of vacuum going in....so I put fogging oil through that rather than pulling coils off. Previous bike had vacuum caps on the carbs and I did the same thing but with a vacuum hose harness I made up. I did this until there was visible smoke from the exhausts and shut it down. Hope this is enough...but pretty sure it is.
Kind of wondering though about the right side fairing where there is that little tab that goes into the upper fairing under the head light that has a quick rivet through it....how the hell do you get that to go in properly? The problem I had was the small guard on the fairing cover for the radiator cap was interfering with getting the tab to go into where it should. Left side was tricky but do able...right hand side was damned near impossible.
Thanx..Ross
