Thread: 3 Questions
Created on: 09/06/10 09:30 AM
Sipho
3 Questions
09/06/10 9:30 AM
-What is the torque spec. for the exhaust header pipes to the head? The manual has only got a spec for the Muffler Body Mounting Bolts at 34nm. When I took it apart the torque was less than 10 nm
-What will the effect be if pure anti freeze is used instead of a 50% mix.?
-If I jam the flies in a open position will I get a F1 error?
Thanks Sipho
RE: 3 Questions
09/06/10 11:19 AM
Bolts-13 ft/lbs.
Anti freeze..don't know
Secondaries locked...most likely...the fly shaft will want to turn.If it's jammed...who knows?I wouldn't lock it.
alg8er
alg8er's Gravatar
RE: 3 Questions
09/07/10 6:15 PM
there are some antifreeze designed to work without water, but if it's designed to use water it won't dissipate heat / cold without it. It would freeze or overheat.
Sipho
RE: 3 Questions
09/08/10 3:08 PM
Thanks Guys.
Did a Google search on the anti freeze. Check this out http://www.gi.alaska.edu/ScienceForum/ASF6/680.html
