Thread: 06 Akrapovice slip ons onto 08 Header
Created on: 08/30/15 03:20 AM
mogsy
mogsy's Gravatar
06 Akrapovic mufflers onto 08 Header
08/30/15 3:20 AM
Hi all,
I'm a newbie just bought my 08 in midnight sapphire black but have ridden one for years in work. Could do with a bit of advice please. I have bought a set of Akrapovic slip ons with link pipes cheap but they are from an 06/07 bike, I know that the headers are a larger diameter on my 08, so my question is, is there any easy way to make them fit with reducers or will I need the headers from an 06/07 bike, would they fit with different gaskets or does akrapovic use gaskets at all?
Thanks all
* Last updated by: mogsy on 8/30/2015 @ 3:24 AM *
yannih
yannih's Gravatar
Queenstown New Zealand
RE: 06 Akrapovice slip ons onto 08 Header
08/30/15 8:17 AM
mogsy, take a look at this.
I know its reversed but it may give you an idea or two...
Yoshi Slip On Issue
* Last updated by: yannih on 8/30/2015 @ 8:19 AM *
mogsy
mogsy's Gravatar
RE: 06 Akrapovic slip ons onto 08 Header
08/30/15 10:17 AM
Thanks Yannih
I tried to search the forums for a solution to my problem, I just don't know if the Akrapovic from the 06/07 use the oem gasket at the header it doesn't show this in the install instructions, also should I sleeve the header end, change the headers as I have cats in the 08's or I can get some 08 Akro link pipes and then sleeve the muffler end?
I'm after the best route to go down
mogsy
mogsy's Gravatar
08/30/15 10:33 AM
By the way Yannih those yoshi's look amazing, wish I could have found some nice ones, I've ended up with some Akro SP cans
