Hi all
the ZX 14 has a catalytic converter in its header. However, it doesn't appear to have the O2 sensor that typically goes with a catalytic converter as found in cars. The O2 sensor in a car monitors the oxygen level in the exhaust before it hits the catalytic converter and that information is typicaly used in a control circuit to monitor and adjust the air fuel mixture by contorlling the amount of fuel injected. So, the ZX 14 fuel injection system, even though it has a catalytic converter, is missing the typical control system to continuously adjust air fuel mixture on the fly. It is essentially a "dumb" system, that relies on pre-sets in the fuel injection map.
My first issue relates to the way that the dyno operators get their air/fuel ratio information, by sticking an exhaust "sniffer" probe up the muffler, taking the air fuel ratio readings AFTER the catalytic conveter. The "cat" has both reduction and oxidation catalysts in it, meaning in plain English that the cat reduces unburned hydrocarbons by oxidizing/burning them. Surely the exhuast gas sniffers used by the dyno operators are providing a false reading of the actual air fuel ratio of a ZX 14, as the reading they are taking is from the muffler, after the cat burns off a bunch of the otherwise burned fuel in the exhaust, which has to result in the reading of the dyno gas sniffer showing the air fuel ratio in the muffler as much leaner than it actually is before it hits the cat?????????????
so, when my ZX 14 with a stock exhaust system was run recently on the dyno, with the dyno operator shoving the exhaust gas sniffer up the stock muffler, the exhaust gas ratio shown on the resulting Dyno Jet chart is showing the exhaust gas ratio AFTER the cat has oxidized/burned off a bunch of the unburned fuel that was in the exhaust before it hit the cat, right???? So, unless the Dyno Jet software has some correcting factor in it for the cat, the resulting exhaust gas ratio chart has to be showing the actual exhaust gas ratio as being much leaner than it actually is before it hits the cat???
So, how the heck can you tune for a proper effective fuel air ratio on a ZX 14 that stil has its cat in place? The dyno my bike was run on is typically used for tuning HAlrey's, and the operator wasn't able to answer my question about the effect of the cat on the air fuel readings he was taking with his gas sniffer, and I wasn't prepared to have him buoild me a custom map on the basis of the gas sniffer stuffed up the stock muffler. Seems to me that the resulting map would have to be rich, even thought eh gas sniffer would then show it to be perfect when the gas sniffer read the exhaust stream AFTER the cat?
So, those running a complete replacement exhuast that removes the cat would then be getting as "true" a fuel air ratio reading as possible from the gas sniffer. Those preferring to keep the stock header (to be able to leave installed a center stand, for example) and add dual slip ons onto the stock header and cat, will be getting a much less accurate reading, and a much effectively richer custom map if done on the same equipment?
I am no expert with fuel injection. I am highly expert with setting up and dialing in carbs on older race bikes. The quality of the result is entirely dependant on the quality of the information available in the dial in process. I am just trying to understand how to dial in the fuel injection on a ZX 14 properly, with a cat still in place. The chart resulting from my initial dyno session shows my ZX 14 running rich from about 3,800 rpm on up, and getting progressively richer as rpm's increase. That is with the gas sniffer taking its readings from a muffler, AFTER the cat has presumably already greatly reduced the level of unburnned fuel in the exhaust stream by further oxidyzing/burning that otherwise unburned fuel. So, seems to me, that the fuel injection settings must be much richer than the fuel air ratio shown by the dyno chart.
I have gone ahead and ordered a PC V, an autotuner, and dual Yosh slip ons, from Fuelmoto last week, and am waiting for them to arrive. Seems to me that the autotuner, taking its readings from a wide band O2 sensor AHEAD of the catalytic converter, may be the only way avaialble to me to proeprly dial in the fuel air mixture, and that when that fuel air mixture map is set using the information from the O 2 sensor ahead of the cat, that if the cat is doing its job, the resulting chart readings of air fuel mixture taken on a dyno by a sniffer stuck up the tail pipe is going to show the result as dangerously lean???
Enquiring minds would like to know. Anyone?
Paul
ps - is there a spell checker here on this site anywhere? I desperately need one, as you can clearly see, above.....
* Last updated by: laverda1200 on 8/5/2009 @ 9:59 AM *
