Mine does it too and has ever since new. I would call it more of a raspy rattle noise. I surmise that it takes a while for the engine to oil up the cam chain tensioner after all oil has run down to the crank case. If you don't leave the bike sit too long, the CCT stil has oil on it so the rattle is shorter or quieter or maybe not even there at all.
I would try full synthetic and see if that doesn't stop the noise. It worked for me but only for a couple hundred miles. Now it just rattles a few seconds - and I don't even give it a second thought. That's a Kawi.
A lot of people seem to go with the Ape cam achain tensioner because it's quiet. I wouldn't spend the money unless my OEM CCT was busted and needed to be replaced.
