timomasalin - Thanks to your response posting the side case details, yesterday I ordered everything I need to mount up a set of Givi V35 PLX Monokey cases, also ordered yesterday
I ordered not only the cases and carrier brackets, but also:
- the SW-MOTECH Keyed Locking Quick-Lock Fasteners (pair) (SKU QLS.00.046.10100.B). "This pair of Lockable Quick-Locks can be used to replace any one of the standard Quick-Locks found on each sidecarrier. The set includes two matched keys. Helps prevent theft by locking the racks to the bike. Redesigned to make this item smaller and easier to grip after unlocking, the lock twists off much like a standard Quick-Lock fastener. Only one pair needed per bike - one lock for each siderack. Take the key out of the lock cylinder when trying to turn the lock. This will insure that the lock is either fully locked or fully unlocked when you turn it. If you leave the key in the unit when trying to turn it, the lock may jam or you may break your key. When installing the Lockable Quicklock, slide it into the siderack, then place the retention washer over the tip of the LQ. Once the retention washer is installed on the LQ, attach the siderack to the mounting tabs on the bike.
" ... $56.95
- the 3-lock matching lock / key set so my side cases & top case all open with 1 key (SKU Givi SL103) ... $51.30
The only cheaper place I could find them was on eBay coming from Italy, and I didn't want to chance them not arriving in time for my Sept trip.
Thanks for the help.
* Last updated by: extrapolator on 8/20/2015 @ 9:55 AM *
