what to do to remove the carbon can under the seat?
Created on: 09/25/09 03:10 PM
hyped
RE: can
09/25/09 3:47 PM
"FOR RACING PURPOSES ONLY:"
Turn to page 123 of your Owner's Manual. If you have an older manual, look on either side of the page until you see that canister diagram. If no manuals, remove seat. As you sit on the bike, look at the left tube at the rear of the tank. This is if rain fills the gas cap area and not fill the gas tank with water once you open the cap after a blast of a car wash sprayer. This tube heads to the ground or that little clear res by the foot shifter area. You can leave that alone.
Look at the blue dot on the tank outlet tube. This is a breather return as is the red dot tube. Run these open to the atmosphere and chuck the rest.
Once you followed the two canister tubes to #3 and #4 intake hose fittings, head for NAPA, get two rubber end caps that resist gas and are made of the same material as the hose or the other rubber nipples that are closed. Pull one off the #1 sync nipple fitting; show that rubber hose cover to the counter person and match the ends and hole size.
You should have the blue and red hoses routed, never to be bent so as they are closed from the air. If your bike stops running or the gas tank implodes, might want to check to see if either or both hoses are kinked.
* Last updated by: Hub on 9/25/2009 @ 3:51 PM *
hyped
