I was curious here...you guys know how everyone(mostly)says to replace the sprockets and chain as one.Okay...say a guy wears out rear sprockets before the chain and all become 'in need of replacement'.Not breaking teeth type of wear...just 'normal' wear...and not down to where the teeth are pointed and dished.Say the chain is in fine condition.Not even close to needing replacement.My question here...not that I'm gonna do this...but...say instead of buying a new chain...what about breaking the chain at the master....flipping the chain over,and turning it around so it's now grabbing on the 'other side' of the links...and reinstalling a new master endless link?Does anyone think this could possibly extend the life of the chain?In an appreciable way?I can't really see how buying a brand new chain because you've worn your 'rear' sprocket(let's say)would be a wise move?I've only replaced the whole shebang at one time once...on my 07.
I'm on my second rear sprocket...doing fine...and the chain is virtually perfect as much as it can be....Just seems like overkill to me to replace all three at one time.Hell...If I did that...I'd be buying the sets at 6,7K intervals....BTW..there's nothing wrong with my alignment or play...I keep her in spec..and clean and lubed religiously.Thanks all for your inputs;)
As a side note...I do not run my sprockets down to anything resembling hooked or 'pointed' teeth.In all reality...they probably could go several K's more....I've never really been one to just run the shit outta my sprockets till they 'fail'.
* Last updated by: Grn14 on 9/23/2013 @ 11:19 AM *
