Thread: Hard rear pedal
Created on: 08/23/24 07:19 AM
Daddyrabbit
Daddyrabbit's Gravatar
Behind you,skewed to the right
Hard rear pedal
08/23/24 7:19 AM
The rear brake pedal on my 13 has been binding lately. Once I depress through the resistance it always comes back up. Everything is adjusted correctly, fluid is bled and fresh. From what I am able to find out it may be the abs module. I have no abs light or fault codes. Can I bypass the rear caliper abs lines?
* Last updated by: Daddyrabbit on 8/23/2024 @ 7:21 AM *
Ile be damned
islandninja
islandninja's Gravatar
Bintan Island, Indonesia
RE: Hard rear pedal
08/23/24 8:14 AM
experienced the exact same issue on my 2013...
checked & serviced the complete rear brake system
then changed the master cylinder assembly
then flushed & replaced the brake fluid... still no good
eventually, getting a new ABS control module fixed the issue... not cheap though
spoke to a Kawi mechanic about this problem
he recommends to use the rear brake as often as possible
this would prevent the choking of valves in the ABS module
Daddyrabbit
RE: Hard rear pedal
08/23/24 5:02 PM
Thats my thought also, it only does it occasionally, if nothing else ile just pull the fuse...
* Last updated by: Daddyrabbit on 8/23/2024 @ 5:02 PM *
Ile be damned
Daddyrabbit
RE: Hard rear pedal
08/28/24 5:15 AM
It is getting better after activating the abs several times at low speeds. Time will tell I suppose.
Ile be damned
islandninja
RE: Hard rear pedal
08/28/24 6:53 AM
hey, this is good news!
