So have you ever heard of caps coming off if the rubber is squeezing up on the res cap, oil filler cap, oil filter bolt? Not me. Do I need a stink-inn-wink-inn clip I dab 2 drops of white dots?
Yup, I'm sure the rez cap works with the diaphragm pretty much the way the fairing fasteners work with well nuts. + if you follow SM instructions, that cap is screwed on there very tight...like if that rez was a jar of honey, you ain't getting that cap back off next time you make your toasted English muffins.
And weight to ounces, Rook.. 4 parts of screw-washer-nut-clip = adds up. 2 paint dots facing you: not so much.
ya, tru dat. the retainer, screw and washer for the brake fluid res cap weighs .30 oz. Lucky me, I have an anodized aluminum retainer and screw from ProBolt. .10 oz.
Hey rook where did you get the blue res. cap ? ebay ? gotta get one,
Mine are from ProBolt and they cost some ungodly price ...$30-$40 or something like that. I bought an entire front brake reservoir with anodized blue cap, plastic plate and diaphragm and rubber hose /w clips for about $16 off of Ebay. Looks JUST like my ProBolt cap. I don't think you will find a clutch reservoir on Ebay. You'd have to go with ProBolt on the clutch rez, I think. The color is almost identical....maybe exact.
In the weight dept, the aluminum caps are a loosing proposition. OEM plastic brake rez cap is .4 oz. ProBolt aluminum is 1.7. Looks mighty snazzy though.
is a honor to be a member of your online community here!
I agree. It is a cool place and far more real than Facebook.
Oh, and I love those blue caras, awesome looking, I think they would look great on my bike ...
Thanks. No longer have the Tri-R for the ZX-14 but I'm sure there is something equally sexy for our bikes from CZ now. Best lightweight wheel option in terms of $/oz. ...and they look sweet, too. Anodizing is very high quality....seems to actually have some thickness to it. No chips from rocks at all.
Drawback: front rotor bolts are small. DO NOT TORQUE TO KAW SPEC!!! I broke one. Major PITA. Also aluminum threads...I go less than half torque spec in aluminum. About a quarter to one third at most and us LokTite. Also big project to safely install 90° valve stems. Check out my valve stem replacement tutorial for CZ 90° valve stem install.
CZ rotors???? not sure they are so great. They work but I got a brand new one and it seemed a little warped. They are very lightweight. You are supposed to use organic pads. YEs, my scintered pads GROAN when I'm on the brake hard. Not so bad now but pretty scary at first. TOo much grab with the high friction CZ rotors and the scintered pads...so it seems.
* Last updated by: Rook on 10/16/2014 @ 6:18 PM *
08 MIDNIGHT SAPPHIRE BLUE ZX-14 Now Deceased, will be resurected
2024 ZX-14R bran friggin NEW!
