Page: 1 2 3
Thread: Here we go with the flies again
Created on: 12/01/11 05:41 PM
12/01/11 5:41 PM
IDK how much of this is true. Sounds totally legit. Long time member at BL, 'Wheelie' reports his 2012 14R has flies about 25% open at 7K rpm.
If that is true, can you imagine the power with flies out? I'm sure the bike makes good power below 7K rpm with flies in.
seno
seno's Gravatar
RE: Here we go with the flies again
12/01/11 5:45 PM
I am happy with the traction control even though it only kicked in a couple of times. Removing the flies will disable the traction control... So what are the options?
DogoZX
DogoZX's Gravatar
12/01/11 5:59 PM
Contact Guhl, Dynatronics, and/or ECUnleashed... bet they're looking for owners for ecu flash... first few usually get it free.
Wheelie
Wheelie's Gravatar
12/01/11 6:18 PM
The 14r pulls strong with the secondaries in, it's nothing like the 06, but I want as much low rpm horsepower as I can get. Just because they seem to open slowly doesn't mean it's weak lol.
wee
2012 ZX-14r
12/01/11 6:35 PM
Of that there is no doubt, Can't wait to try one. None here yet.
Yikes, could you imagine.
Wheelie when you taking them out ? Testing purposes of course lol Can't wait to read your report.
No, but fun to play. Worth a try, No ?
12/01/11 6:41 PM
I'm hoping to go this way,,, this time. I want all the software 2 not just the Flash. Would be Awesome, just think, No pcv 5, no auto Tune No speedo healer No ignition module,,,,,the list is endless,,, Then I woke up. Full open ECU would be a dream. Data log and go ????
Wheelie
Wheelie's Gravatar
12/01/11 6:42 PM
they are out. As Brock says, it's stupid fast
wee
2012 ZX-14r
12/01/11 6:44 PM
IF the secondaries are actuated at the throttlebodies as the previous ones...then the stacks don't really 'know' whether they're open or not,yes?I'm just guessing here.So removing them wouldn't actually affect the Ktrc would it?I mean..the actuator shaft would still be thinking they're in there,right?IDK.And if so,then I would think that the KTRC would just 'react' quicker in certain instances...but not actually cause any performance problems...yes?So you could 'probably' get the low end punch...just quicker and the Ktrc would respond accordingly IF the wheel broke loose or something?Unless of course,the fuel/air mix is being monitored for a certain throttle position...set in the ECU and all.Then,it may not help to remove em?I mean,you punch the throttle in first or whatever...get your preset fuel going(for whatever that position is),and now an addition of more air before 7000...would the ECU 'see' that and try to correct it?IDK.
* Last updated by: Grn14 on 12/1/2011 @ 6:49 PM *
12/01/11 6:47 PM
Rook stock wheel base may be to much but u can bet Track guys going to be extended and on this like a cougar on a cripple chicken lol. Man,,, Can't wait getting excited. You getting one ?
Wheelie
Wheelie's Gravatar
12/01/11 6:48 PM
if you want them out, remove the fairings so you have quick access to the airbox, ride around and get the bike hot, this will loosen the locktite, use a "quality" #2 screwdriver, preferably a J.I.S screwdriver pressing down firm and make very slight turns.
wee
2012 ZX-14r
12/01/11 6:50 PM
Out, Reallllly, Do tell ???? Before compared to after. There will always be the guys that say no diff. Impression is ?
Wheelie
Wheelie's Gravatar
12/01/11 6:52 PM
it spins on the street where it didn't before, I'm happy, now if I can find the coil wires on the ecu, not the same color as a Gen 1, air shifter waiting.
wee
2012 ZX-14r
12/01/11 6:55 PM
Can't tell from pic you have shown,,, old bike ? Does new one have swing Arm ? Lowered ?
DogoZX
DogoZX's Gravatar
12/01/11 6:57 PM
Pipe dream... unless you have a Busa.
Still gonna need a PC to tweak fuel... and if that's the case, might as well put on a WB2... but if I had a 14r, I'm fairly certain I could get flash and dyno time on the house for being the guinea pig... That toy I brought home a couple weeks ago... that came from my tuner.
12/01/11 6:57 PM
Apparently from what I read..the Ktrc is actuated by a combination of wheel movement and ignition timing.I'm not sure(at all)that fuel mix has anything to do with the actual Ktrc system.The earlier models gained punch from the extra air available without the plates blocking it,right?So isn't this the same deal?IDK.If so,then the mix will come in sooner,like the early ones.The Ktrc doesn't do anything UNTIL it reads a traction problem.That's what I get out of it anyway.Mapping down low might be necessary to get the full benefit of fly removal...just like the early ones?
That avatar is an earlier model.Not a 2012.Wheelie mentioned 'spins on the street'....I guess it will if the Ktrc is turned off.
* Last updated by: Grn14 on 12/1/2011 @ 7:01 PM *
12/01/11 6:59 PM
Hmmmm, so when does your bike get in ? lots of info needed over our winter lol Batter up,,,, You in ?
Ouch, going to my room now
* Last updated by: Romans on 12/1/2011 @ 7:03 PM *
Wheelie
Wheelie's Gravatar
12/01/11 7:05 PM
correct Grn14
wee
2012 ZX-14r
12/01/11 7:09 PM
How does it compare from a dig to the first gen 14 with flies out ?
Wheelie
Wheelie's Gravatar
12/01/11 7:11 PM
feels about 15-20 hp more.
wee
2012 ZX-14r
12/01/11 7:13 PM
Can you post some pics ?
Wheelie
Wheelie's Gravatar
12/01/11 7:15 PM
pics?
wee
2012 ZX-14r
12/01/11 7:21 PM
Pictures
Wheelie
Wheelie's Gravatar
12/01/11 7:22 PM
wee
2012 ZX-14r
12/01/11 7:25 PM
She's BADAZZ...for sure!
12/01/11 7:27 PM
SWEEET, I can see links,Muzzy M-10 Gearing ??? What else if you don't mind me asking. Sorry but this info is rare
Page: 1 2 3
