Anyone have a preference on LED turn lights, and brake light? I came across these here;
2010 Ninja 250
2012 Ducati Monster 696
Created on: 08/06/12 01:14 PM
caps
caps
dericrey
RE: LED's
08/10/12 4:54 PM
I like the rear turn signals on the black bike above. I wish I could find those with a matching set for the front. I replaced my bulbs with LED bulbs, LED flasher then blacked them out with VHT Nightshade spray.
caps
dericrey
RE: LED's
08/11/12 8:28 PM
Bulbs from here autolumination
I ordered these for the 2 front running light:
T10 Wedge Item# Super Nova Matrix 3 Watt , Color: Super White , Lens: 194
I ordered these for all 4 turn signal bulbs:
Bayonet Item# Matrix II 32led , Color: Amber , Type: 7507
*the 4 turn signal bulbs where a little too big to fit through the socket hole, in the rear I put the bulbs in by just removing the lens while still mounted on the bike, in the front I used a stone on a die grinder to make the socket hole bigger* (you may want to go with a smaller size bulb)
The relay is here : LED flasher
RE: LED's
08/14/12 7:31 AM
Good information, thanks!
My 2012 Connie already has an LED brake light, but the turn signals are standard bulbs. I am not sure I can replace them because I'd have to use the LED flasher module, and not sure how it would affect the AdMore light harness for my top case.
mebgardner
RE: LED's
08/14/12 4:52 PM
I like mine alot.
They get me lots of room from behind, minimizing tailgating. The flickering is subtle, but riveting. As soon as they were installed, I noticed the difference in cager attitude from behind.
Skene Design P3 Lighting.
VigilanteZERO
RE: LED's
07/11/13 2:29 AM
I'm a little behind the power curve here, but I got a few from superbrightleds.com with a CustomLED ELFR-P programmable flasher, and I'm thrilled with the results. Didn't have to mod the turnsignal housings or screw with the lenses to fit the bulbs either, so I was pretty happy about that.
Light bulbs: http://www.superbrightleds.com/moreinfo/tail-brake-turn/led-product/527/
Relay: http://www.customled.com/products/flasher_relay/flasher_relay.htm#LayoutRegion2LYR
There are ten modes on the relay, I have this same flasher relay on both my 14 and my VF750C, and I love them. They'll work with incandescent loads, LEDs, or a combination of both.
cjuni
