Thread: Tire Removal and Mount
Created on: 03/26/14 01:01 PM
03/26/14 1:01 PM
If you only replace tires one or two times in a season, changing your own tires may not something that is going to be financially practical. Tire mounting tools can be purchased for a small investment but the time it takes and the fact that you will have old tires to dispose of (which will probably cost you $10/tire) will make the dealership shop’s prices start to look more attractive. I’ve found the retail price of tires from a dealership to be within ten dollars of the price online plus sales tax which the dealership collects at the time of sale.
I decided to start changing my own tires because I own expensive aftermarket rims and I have had bad experiences in the past getting my rims back all scratched along the edge. If you take the time to learn the process, you should be able to avoid careless damage like that. Tire changing is rough work, however. Chances are, something will drop or slip and a rim will get a scratch eventually.
The following link is to a pdf tutorial by Adam Glass. Mr. Glass’ tutorial has a plethora of images and detailed descriptions that I am sure will explain most if not all you will need to know if you decide to start removing, mounting and balancing your own tires. Glass goes into detail on a number of things that I will not cover in my tutorial. It is all good information, however I will take issue with one suggestion made by Mr. Glass. The use of plastic water bottles as rim protectors is not to be trusted when using tire irons. I used this technique one time and had success. The other time, the tire was so tight that the tire iron levered down hard enough to crack the plastic. This left a small scrape on my rim. It may be safer to use plastic bottles of a different thickness (I used milk bottles folded in half) if you are going to improvise rim protectors. To be completely safe, I strongly recommend using ONLY the specifically designed rim protectors such as those sold by Motion Pro and other suppliers.
CLICK LINK>>Motorcycle Tire Changing
links to other threads about tire changing.
Tools:
air line and quick connect fittings
Sharpie
valve core tool
tire changing stand
1/2 inch plywood, three and a half inches square
bead breaker
soap and water solution or tire mounting lube
4 rim protectors
string
3 fifteen inch tire irons
steel wire (optional)
safety goggles or a face shield
new valve stem
wheel balancing stand
blowgun
new tire
ball foot clip air chuck
thumb lever control air hose attachment
Tools Overview
Valve Core Tool. These are easy to find and inexpensive. I would not try to use some other tool to remove or install a valve core. The valve core remover is just a simple bit that fits nicely to the two flats of a valve core. These tools have flats but you should never need to use a wrench on them except perhaps to remove a rusted valve core. Valve cores are not to be installed more than hand tight. Might as well pick one of these tools up. The one in the pic is distributed by Motion Pro. Like most tire changing tools we will discuss, the majority of valve core tools sold by different companies are identical in shape.
Tire Changer Stand/Bead Breaker. They are called by a variety of names such as “Black Widow” or “Shadow” but as far as I can tell by the online pictures in the ads, they are all identical. Basically the tire changer does nothing but hold the wheel steady when you break the beads and lever with tire irons. The bead breaker is a long lever that is used to press a hinged blade down against the tire. The blade presses the bead away from the rim as one of the first steps of tire removal.
Both a bead breaker and a tire changing stand can be made at home with some easy to find items but for $90, you can buy one of these and be almost ready to go out of the box. It works well and will not damage rims. Be careful to avoid over-tightening the wing nut on the threaded rod that runs through the center of the wheel. You do not want to inadvertently press your wheel bearings deeper into the wheel hub. Use one hand and just snug the wing nut up finger tight after it makes contact. This will secure the rim.
Tire Soap or Tire Lube. Use enough of it but don’t over do it. Too much may cause the tire to slip on the rim after the wheel is installed and in use. For tubeless tires, this won’t cause the bead to come unsealed or any other type of deflation hazard. Still, a slipping tire bead may affect wheel balance. It also can reduces power that is transmitted to the ground which may be a factor if you are racing. Too much soap may also result in moisture being trapped inside of the tire and that may encourage corrosion and affect wheel balance as well. I soaped the rim and the tire one or two times and then used plain water if the soap dried up. I used about 1 part dish soap to 4 parts water. Many people have sworn by the commercially prepared products known as tire lube. Those proprietary gel concoctions might have some ingredient that makes them superior but I have no experience with anything other than dish soap.
Rim Protectors. Use them at all times when placing a tire iron on the rim. They protect the outside from suffering cosmetic damage and the inside from suffering scrapes that will prevent the tire bead from sealing. I used 4 rim protectors at a time but having a couple extra on hand is advisable. Always use a heavy string to tie the rim protectors tightly to the center rod of the tire changer stand. This will prevent the rim protectors from falling to the inside of the tire leaving your tire iron to scrape on a bare rim.
These are the rim protectors I used. They are made by Motion Pro but there are other brands that look identical.
Tire Irons. There are a number of different kinds of tire irons that can be purchased. I chose the long 15 inch tire irons because the handles are easier to hold for the manipulations that are required when working alone. I did not choose them because of the significantly greater amount of leverage that can be applied with a long handle. I think the suggestion to not use a tire iron that is much longer than your hand is sound. The power that is at hand with 15 inch levers might bend some rims. When using the tire irons to lever the tires onto the rim, I tried to hold them closer to the middle of the iron rather than at the end. Use the curved end as the point and the straight end as the handle (as shown in the illustrations that follow).
It’s next to impossible to hold one iron down and insert the next one. Using three tire irons as I suggest in this tutorial is out of the question unless you have a second person to assist you. After prying the bead out of the rim, I used a heavy gauge steel wire to fasten the tire iron in place while I positioned the next tire iron. This makes a one man job possible but obviously it entails some risk. If you use this technique (see the photo in step 10) be very careful that the wire is secure and the iron will not move while your hands are off of it. If a wire slips or breaks, that will send the tire iron flying through the air, possibly hitting you while you work.
Air Compressor. I had luck using a sixty dollar, 3 gallon pancake compressor from Harbor Freight to seat my tire beads (the line and quick connect fittings were sold separately). It will do the job if both of the tire beads are contacting all around the rim. If the tire bead is not touching all the way around the rim on both the left and right sides, air will rush out as quickly as you can deliver it from a small compressor. In this case, it may be necessary to use a more powerful compressor or one with a with a large capacity tank such as an 80 gallon.
Ball Foot Chuck. Any chuck will work to inflate the tire but to seat the beads you need a chuck that will allow 100% unrestricted airflow into the tire so that it will inflate rapidly enough to push the bead(s) against the inside of the rim in less than one second. If it takes a lot longer than a second with a small capacity compressor tank, all the air will escape from the tire and there will not be enough air left in the tank to seat the beads. A ball foot chuck with the valve removed works great to deliver maximum volume from your compressor tank. The ball foot chuck valve removal process is described in detail in step 36 of this tutorial.
Pointers
Rule #1: DON'T Touch the bead surface of the rim! There are two bead surfaces inside each rim. One is vertical and it is pretty well protected from tire iron contact by the rim protectors you will use. The other bead surface is the adjacent horizontal surface inside the wheel. This has NO protection while you remove tires. Do not insert an iron so that it levers on, scrapes, rubs or touches this surface. If it is scratched, the tire may not seal. The bead surface of the rim will need to be polished to repair the damage.
The method of tire iron use is to pry the tire bead over or under the rim edge (according to whether you are removing or installing) with a tire iron. This iron is kept in position to “stake” the tire bead in place while a second iron is used to to pry the next section of bead. Both of these tire irons are held in position as a third iron is used to pry up the next few inches of tire bead adjacent to the second. The second tire iron is removed, placed ahead of the third and the next section of bead is pried. The first tire iron does not get removed. Tire iron two and three alternate or “leapfrog” around the rim until the tire bead is pried over (removing) or under (installing) the rim. This will be shown more clearly in the tutorial later on. Also, note that the iron should be inserted so that the curve is always facing up after the tire bead has been levered over the rim. This is the case for both installing and removing.
The tire irons require greater force as more of the tire is levered into place. A large length of bead will require more force to lever into place than a small length of bead. Be careful not to attempt to lever too long of a length of tire bead in one step. Smaller steps require less force and and are less likely to bend the rim. Be especially careful with lightweight rims.
Rear rims are larger and easier to lever tires onto than fronts. You might want to start with a rear wheel to get the hang of it. The front is about 25-30% more difficult.
Use the wire technique at your own risk. One person alone simply does not have enough arms to use three tire irons at the same time. For this reason, I have used wire to hold the tire irons after the tire has been levered into position. The tension is reduced at that point but there is still a danger that the tire iron could slip out or the wire could come unfastened somehow. A second person acting as a third and fourth hand is a better alternative if you have that at your disposal.
It may be advisable to remove rotors and sprocket from the wheels before starting the process of using tire irons. The reason is that these parts need to be especially flat to function properly. With the great amount of force being applied to stretch a tire over a rim, It is very possible that a tire iron may accidentally pry against a rotor. Before you know it, the rotor is warped. At any rate, if you do discover your rotor is warped one day, you don’t want to be wondering if it was caused by putting on your own tires. So I recommend removing discs and sprocket before using tire irons--at least for your first several tire changing experiences.
Never lift the rear wheel by the sprocket. If you decide you don’t need to remove the sprocket, be careful not to use it as a lifting handle for the rear wheel. The sprocket is bolted to a carrier but the carrier is only pressed into place over the cush drive with hand pressure. It fits tight but the carrier can pull right out under the weight of the wheel and the wheel drop on the floor.
Always wear eye/face protection. There is a lot of tension in a tire as it is mounted to a rim. Using tire irons, especially when wiring them in place, there is a lot of potential for something to fly up at your face. You might loose a tooth but at least you can keep your eyes protected if you have on safety goggles or a face shield.
Drop center of rim Looking at the inside of the rim, the center portion where the air valve is situated is lower than the bead surfaces of the rim. The center is often made extra low to make tire mounting a little easier. As the tire is levered over the bead, it may be pushed up into this low spot opposite of the tire iron. This will add a bit of slack that will come in handy when the tire requires more force to lever as work progresses. However, like tire lube, don’t become overly reliant on it. Using the drop center too much can cause the tire to become cocked on the rim and bed seating to be difficult.
It is not a bad idea to mark the direction of rotation on the wheels with a Sharpie to eliminate confusion during tire installation. The OEM front ZX-14 wheel has a rotation direction indicator arrow molded into the surface of one spoke. You may still want to mark an arrow on both sides of the front and rear rim so you can easily match that to the rotation mark on the tire. Don’t accidentally install a tire with backward tread.
Finally, practice. Use old rims to mount your first set of tires. If you need tires on your expensive rims and you have no experience mounting them, you might want to find a shop with a very good reputation for NOT scratching rims and bring the wheels there. Then again, pretty much no shops I talked to guaranteed that my rims would come back without a single scratch. Owners I’ve talked to about this tell me they get their tire changes done complete with fresh scrapes on the rims every time. Most shops don’t take the time to avoid this and they can’t afford the liability to guarantee it won’t happen. Tire changing requires an awful lot of force. I consider myself extremely careful about working on my bike and I take a great deal of time to learn to do procedures without causing damage. I still put one small mar on my aftermarket rim and I dropped my OEM rim on the tire changer stand (carrying it by the sprocket) which scraped the finish. Of all the wrenching I have done, tire changing is by far the most brutal. It is not possible to be gentle every bit of the way.
Tire Removal
RECOMMENED: Break loose the rear sprocket nuts (See Sprocket / Drive Chain Replacement, step 9). Break loose the front and rear rotor bolts (see Front and Rear Brake Disk Removal, steps 1and 2). I also suggest that you mark the rotors, sprocket, nuts and bolts with a sharpie so that they can be reinstalled exactly as they came off for precise wheel balance (see step 14 of this tutorial).
Remove the wheels from the motorcycle (see Front And Rear Wheel Removal, steps 1through 9 and steps 20 through 32).
The following directions for tire removal apply the same to front and rear wheels. However, rear wheels are a lot easier than fronts.
1. Check the tire air valve stem and valve core with soapy water to determine if it is leaking and needs to be replaced (see Tire Air Valve Replacement).
Remove the valve core from the valve stem using a valve core tool. All the air will come out of the tire. Save the valve core in a safe place. It is best to remove and install tires with the valve core removed.
2. Carefully place the wheel on the threaded rod of the tire changing stand. The wheel may fit differently according to which side is facing down, sprocket side or rotor side. When the stem points down, ninety degree valve stems will only fit in the open spot on the top ring of the tire changer. The main point is that the wheel needs to rest with its spokes against the top ring of the tire changing stand. No other part of the wheel should touch the stand.
3. Cut a piece of 1/2 inch plywood, three and a half inches square with a 3/4” hole drilled into the center. Place it on the threaded rod between the wheel hub and the wing nut. Gently snug the wing nut finger tight against the wood. Do not over-tighten the wing nut or the bearings could become pressed to an improper depth in the hub. If you have not already done so, mark the direction of wheel rotation on the rim with a Sharpie.
4. Adjust the bead breaker to the proper position so that it will not gouge inward at the rim. Use the bead breaker lever to press the bead down away from the inner edge of the rim. Loosen the wing nut, rotate the wheel a few inches, tighten the wing nut and repeat the bead breaking process. The bead will usually be sepperable by hand after approximately 6 inches of the bead has been broken with the bead breaker.
If the center threaded rod interferes with the lever of the bead breaker, lower the center rod as shown in the picture below. Push the bottom portion of the rod into the ground so that the tire changing stand will sit level while the bead is broken.
5. Remove the wheel from the tire changer and put it back on the tire changer with the opposite side facing up. Repeat steps 2-4. The bead will usually break around the entire circumference of the rim after one press of the bead breaker.
6. After both beads have been broken, determine which side of the wheel you want to have facing up for the remainder of the job. Put the wheel on the tire changer and use a soap and water solution or tire mounting lube all around the edge of the top edge of the rim and the top tire bead.
7. Arrange at least 4 rim protectors on the edge of the rim like so. Make sure you tie them with string to some part of the wheel so that they cannot fall in the tire while you work.
8. Apply some lube to a tire iron and place it on top of the first rim protector. Hook the tip of the tire iron under the edge of the tire bead. Lever the tire iron down against the rim protector. Hold the tire iron down in this position.
9. Place the next tire iron (yellow) on a rim protector next to the red tire iron. Insert and lever the yellow tire iron down as described in step 8, above. Hold the yellow tire iron in place. Do not remove the red tire iron.
10. If you are not securing the irons with wire, you will need a second set of hands at this point. Place a third tire iron (blue) next to the yellow tire iron. Insert the blue tire iron between the rim protector and the tire edge as described in step 8. Lever the blue tire iron down and hold it in place.
If you do not have a partner to help hold tire irons, it is possible to hold the tire irons down with some wire that has been precut. Wrap the wire around the wing nut to secure the levers. The tension is not great but take care! Wear safety goggles or a face shield! The rim protectors should also be tied off to the center rod to prevent them from falling into the tire.
11. It may be possible to remove the red tire iron without having the bead snap back under the rim edge. I suggest leaving the red tire iron as positioned for now to be sure the tire bead remains staked in place. Remove the yellow tire iron and reposition it farther down the wheel radius on the other side of the blue tire iron. Insert the yellow iron and lever the bead up.
Re-lube the tire bead and reposition the rim protectors forward on the rim as needed. The tire will get tighter as it is stretched so take smaller bites as you progress.
You should be able to remove the red tire iron by the time you get past one quarter of the way around the rim.
Continue leap frogging the tire irons all the way around the circumference of the wheel until the tire is entirely pulled over the edge of the rim.
Pull the entire circumference of the upper bead over the top of the rim.
12. Lift the tire up so that the lower tire bead contacts the top inside edge of the rim. Repeat steps 6-11 on the lower bead of the tire. The bottom bead is pulled to the outside of the rim in the same manner as the top but the bottom bead will come off easier than the top bead.
Bottom bead removal with irons wired to the center rod wing nut.
13. Remove the tire from the rim and remove the rim from the tire changing stand. Replace the valve stem if it is rubber. (rubber valve stems are supposed to be changed every time the tire is changed. (See Tire Air Valve Replacement, steps 1 through 3 or steps 5 through 7).
14. Loosely install the rotors and sprocket along with the bolts and nuts exactly as everything was removed. Place the rim with tire removed on a wheel balancing stand to determine where the heavy spot is on the rim is (see Wheel Balance, Steps 1-3).
Tire Installation
Before installing the new tire to the rim there are four marks to take note of. The direction of rotation mark on the rim, the direction of rotation mark on the tire, the heavy spot mark on the rim and the the light spot mark on the tire.
The direction of rotation mark on the rim was applied to the rim with Sharpie in step 3, above or in some cases there is a mark placed on the wheel by the manufacturer. This simply identifies which direction the wheel is meant to be installed on the bike. Also, the wheel must be installed in the proper direction of rotation so that the brake rotors mate to the proper caliper or the sprocket to the drive chain.
The direction of rotation mark on the tire is molded into the exterior sidewall of the tire. This mark needs to match the direction of rotation mark on the rim in order for the tire sipes to function properly.
The heavy spot of the rim mark is a piece of tape that you apply to the rim after the rim is tested on the wheel balancing stand (see Wheel Balance, step 3).
The light spot of the tire mark is a red or orange dot that the tire manufacturer puts on the tire. If the the heaviest spot on the rim is aligned to the lightest spot on the tire, the two help balance one another out, reducing or eliminating the amount of balancing weights required.
The preceding information about marks that need to be considered when installing tires applies to both front and rear wheels. The actual procedure of installing front and rear tires differs somewhat so I am detailing both.
Rear Tire Installation
15. If necessary, change the tire air valve before proceeding (See Tire Air Valve Replacement). Carefully determine how the rim and tire will best be placed on the tire changing stand to allow for easy alignment and visibility of the weight marks and direction of rotation marks on the rim and the new tire. Either side of the rim may face up according to what works best for your needs. Place the valve stem so that it fits in the joint of the top ring on the tire changing stand if necessary (as with the angled valve stem, see step 2 above).
Place the plywood square on the threaded rod of the tire changer. Thread the wing nut onto the rod finger tight so that it contacts the wheel without compressing the wheel bearings.
16. Use a blowgun connected to an air compressor to blow out any debris that may have settled into the new tire .
* Last updated by: Rook on 3/18/2018 @ 5:42 PM *
RE: Tire Removal and Mount
03/26/14 1:34 PM
17. Lube the top edge of the rim and the bottom bead of the new tire.
18. Place the tire on the rim. Be sure the direction of rotation mark on the tire matches the direction of rotation mark on the rim. Line up the weight marks so that the light spot of the tire is at the same point of the wheel circumference as the heavy spot of the rim.
Push one side of the bottom bead over the rim edge and allow it to rest at the drop center of the rim. This will offer some slack to continue to push the bead around the rim edge.
Rock the tire while pushing it down. If you are heavy enough, you will probably be able to push the entire lower bead over the top edge of the rim without using any tools. Be careful, it will drop to the lower rim edge suddenly as the final few inches of bead slips over the top edge of the rim. If the lower bead cannot be pushed over the top edge of the rim by hand, you need to use rim protectors and tire irons as described in the following steps for the top bead.
19. Double check that the the orange dot on the tire lines up with heavy spot that was
marked on the rim. If your rim has no particular heavy spot, might as well align the orange dot to the valve stem for ease in locating during tire inflation.
Lube the top tire bead and the top rim edge so that they will slide past one another easier. Maintain the alignment between the orange dot on the tire and the weight mark on the rim. Push as much of the top bead under of the edge of the rim as possible and hold it to the drop center of the rim. Insert rim protectors at 9 o’clock and 3 o’clock as shown and tie them off so that they do not fall into the tire and allow your rims to get scraped. Use tire iron BLUE to lever the top bead of the tire to the inside of the rim. Hold tire iron BLUE in place.
You may wish to have wire attached to the bottom ring of the tire changer ready to secure the tire irons as you proceed with installing the tire.
20. Lube tire iron YELLOW and insert it on top of the rim protector opposite of tire iron BLUE. Use tire iron YELLOW to lever the top bead to the inside of the rim. Hold tire iron YELLOW in place along with tire iron BLUE. Push the bead that is inside the rim down toward the drop center to relieve some of the tension.
21. Half of the top tire bead needs to be held in place inside the top edge of the rim. If you are not using wire to secure the tire irons as you work, you will now require a partner to help hold the tire irons. Place a third rim protector next to tire iron BLUE and use tire iron WHITE to lever the next few inches to the inside of the rim edge. Hold all three tire irons in place.
22. Leapfrog tire iron BLUE over tire iron WHITE and lever the bead between them to the inside of the rim. Hold tire iron BLUE in place. Do not remove iron YELLOW, it will remain to stake the bead in place while the rest of the top bead is levered, step by step over the top edge of the the rim.
Continue alternating tire iron BLUE and tire iron WHITE around the bead. Leave tire iron YELLOW secured in place. Rewet the next few inches of tire bead and rim as needed.
The bead requires increasing force to lever it over the rim as the work proceeds. Notice that the steps between the tire irons get smaller as they progress around the rim. Taking smaller steps is a way of reducing the force that is required which is safer for you and your rim.
Remember to lube the tire, rim and the tire irons as needed. Also, push the bead that has been levered over the edge of the rim toward the drop center if more slack is needed.
Another trick I discovered to pick up a little slack is to start leapfrogging the irons from the opposite side where the bead was staked. Tire iron BLUE was taken from it’s place behind tire iron WHITE and placed way ahead next to tire iron YELLOW. The bead will have less tension on this side where it has not been stretched repeatedly. Push the bead down toward the drop center of the rim at tire iron YELLOW to relieve a little tension. I save these tricks for near the end of the job when when any little bit of extra slack is useful.
Now tire iron WHITE becomes the stake and tire irons BLUE and YELLOW will leapfrog.
To finish without prying excessively hard on the rim, I pressed the levers down on opposite sides of unfinished portion of bead. This popped the last bit of tire bead over the rim edge. When the tire beads have been levered to the inside of the rim, the weight marks should be fairly close to lining up. They often move a little bit from all the stretching and pulling.
Front Tire Installation
23. For front tire installation, follow the procedures in steps 15-19 of this tutorial.
Place the front tire on the rim. Be sure the direction of rotation mark on the tire matches the direction of rotation mark on the rim. Line up the weight marks so that the light spot of the tire is at the same point of the wheel circumference as the heavy spot of the rim.
Push as much of the bottom tire bead as possible to the inside of the top edge of the rim and and hold it to the drop center.
Insert rim protectors at 9 o’clock and 3 o’clock.
24. Soap up tire iron ORANGE and tire iron GREEN and insert them on top of the rim protectors. Lever the bottom bead on both sides inside the rim. Now along with that which was pushed into the drop center, half of the bottom tire bead is in place. Hold tire iron ORANGE and tire iron GREEN in place. Soap up two more rim protectors and slide them under the tire between tire iron ORANGE and tire iron GREEN. Tie off the rim protectors to the center threaded rod.
If the rotors are not removed, take great care not to bump or pry against them. I placed a rag over the rotor to prevent accidental scratching.
25. Soap up tire iron WHITE and insert it between the rim protector and the tire bead. You will find it much easier to insert tire iron WHITE if you do so while simultaneously removing tire iron GREEN. Lever the tire bead to the inside of the rim with tire iron WHITE. Hold tire iron WHITE in place. Tire iron ORANGE stays in place to stake the bead.
It helps to reduce tension in the tire and avoid interference with the top bead if the tire irons are positioned vertically.
26. Lube tire iron GREEN. Place it a little farther down the bead closer to iron ORANGE. Insert tire iron GREEN between the tire bead and the rim protector while removing iron WHITE. Lever tire iron GREEN down and hold it in place.
I rewired tire iron ORANGE so that it would stand vertically.
27. The last quarter of the bottom bead may be pushed on by hand if you are able to
create enough down pressure on the tire with your bodyweight .
I was able to remove all tire irons and push the remaining expanse of lower tire bead under the top rim with my hands. Be careful. The last bit of lower bead will snap under unpredictably.
28. Now it is time to lever the top bead inside of the rim. Place two rim protectors opposite of one another and a third protector near the one on the right. Tie off all rim protectors to the center rod of the tire changing stand. Lube the top tire bead and the top rim. Line up the orange dot on the tire with the heavy spot that was marked on the rim. Push as much of the top bead as possible to the inside of the rim.
29. Place tire iron YELLOW between the inside of the tire bead and the rim protector. Lever the tire bead over the rim and hold tire iron YELLOW in place. Tire iron YELLOW will remain in this position until most if not all of the tire bead is levered over the rim.
30. Place tire iron RED between the inside of the tire bead and the rim protector that is opposite of tire iron YELLOW. Lever tire iron RED so that the tire bead is pried under the rim. Hold tire iron RED in place along with tire iron YELLOW. Half of the top bead is in place.
31. Insert tire iron BLUE between the inside of the tire bead and the rim protector next to tire iron RED. Use tire iron BLUE to pry the tire bead under the rim. Hold tire iron YELLOW in place along with tire irons RED and BLUE.
32. Tire iron RED is removed and placed ahead of tire iron BLUE. The tire bead is levered over with tire iron BLUE and held in place along with tire iron RED and tire iron YELLOW which has still not been moved.
33. The process of switching one tire iron over the other continues.
34. A fourth rim protector is placed on the rim. Iron RED leaps over iron BLUE.
BLUE over RED,
RED over BLUE,
35. Things get interesting as the front tire bead nears completion. The bead becomes very tight. The process continues however. Tire iron BLUE is placed next to tire Iron YELLOW. It seems to offer a bit more slack to switch tire iron BLUE to this spot instead of continuing to switch places with tire iron RED.
Tire iron YELLOW is now removed and switched over tire iron BLUE.
The tire bead is so tight at this point that it holds itself on the rim without tire irons. It was quite a battle to get the last bit of bead inside the rim. Removing the tire irons offered a tiny bit more slack to insert the final tire iron. The tire bead was finally stretched over the rim by levering carefully in on one tire iron while pushing down on the last bit of the tire bead. It finally snapped over.
Seating the Tire Beads
The procedure for seating tire beads is the same for front and rear wheels.
36. Remove the valve from a ball foot clip air chuck. Unscrew the valve stem clip. and take out the rubber gasket and small brass valve.
Put the gasket back in leaving the valve out and screw the valve stem clip back on.
37. Attach the valveless ball foot clip air chuck to an air hose and you have an ideal air chuck for bead seating. For added safety, a thumb lever control air hose attachment between the ball foot chuck and the air line is suggested.
38. If the valve core is in the valve stem, remove it using a valve core tool. Adjust the regulator of your air compressor so that the tire will be inflated to max suggested inflation pressure (marked on the sidewall of the tire, usually about 42 psi). Make sure your fingers and all other body parts are well clear of the tire bead! Clip the ball foot chuck on the valve stem (press the thumb lever control if you are using one) and the tire will rapidly inflate. You should hear two loud POPS like small firecrackers if both beads have seated against the rim. If you only hear one POP, check if both beads have seated simultaneously or if only one has seated. If only one has seated, repeat the inflation to max suggested psi. If max inflation pressure does not seat the beads, increase the pressure.
I was using 100 psi from my tiny 3 gallon pancake and it was NOT getting the job done on a tire that had the beads cocked on the rim. I ended up taking the wheel to a tire shop. The man charged me $5 to seat the bead with his 30 gallon tank set at 80psi.
39. When the tire beads are seated, remove the ball foot chuck. All of the air will rush out of the valve stem. Reinstall the valve core with the valve core tool. Inflate the tire to proper air pressure and balance the wheel with the the valve stem, rotors, sprocket and tire installed exactly as they were marked for reinstallation (see steps 5 and 6, Wheel Balance).
40. Reinstall the wheel to the motorcycle (see steps 13 through 25 and steps 40 through 53, Wheel Removal and Installation).
* Last updated by: Rook on 3/18/2018 @ 9:19 AM *
08/27/14 1:26 PM
If you have a big problem removing a tire,
08/28/14 7:43 PM
Great work Rook. Damn, that's a pro tutorial. Takes a lot of time to make these things, I know cause making videos pretty much doubles a projects time then having to edit it (not everyone does, I do).
08/28/14 9:03 PM
Ya, as if I don't spend enough time wrenching, then I go and shoot pics.
Thanks for the compliments, Vic. My true feeling is that tire changing is for the birds unless you go through tires really often. Then it makes sense to get a Cycle Hill or NoMar system which everyone says is much easier. ...but I'll keep my lil tire changer stand and irons for now.
08/29/14 8:11 PM
Something tells me you have enough fun on your bike it's worth it!
06/11/16 11:50 AM
Holy crap. 3~4 hours in the sun on a 75° day, the top bead came off SOOO much easier! 2 year old tire, warmed in the sun, pure dish soap, three tire irons, one third of the way around, came right off like wet galoshes. I flipped the tire over and set it out again. The bottom should be a snap. Of course, having some experience helps but getting that tire just warm--- makes a HUGE difference.
DogoZX
DogoZX's Gravatar
06/13/16 11:31 AM
Great write up!
Thank you for reminding me just how much and why I love my no-mar.
Mmm... Potatoes.
* Last updated by: DogoZX on 6/13/2016 @ 11:32 AM *
06/13/16 2:02 PM
Great idea. I might hang on to these.
Now as far as sunshine on my shoulders goes, I have to say it only helps remove the tire by about 20%. I still had to cut the bead cables on the front with a dremmel after getting two tire irons in. Then I was able to pull it off by hand.
* Last updated by: Rook on 6/13/2016 @ 2:02 PM *
DogoZX
DogoZX's Gravatar
06/13/16 3:21 PM
When it comes you mounting/dismounting tires... the sun is your best friend... and dunlops are your worst enemy.
06/13/16 8:52 PM
That's what they were, the same Dunlops you see in the pics above. I've heard the same thing about Bridgestone and can attest, those were a beotch to get on and off too. The Supercorsas did not seem too bad to put on the busa. I hope they come off easy. They sure weren't on there long so that should help.
DogoZX
DogoZX's Gravatar
06/13/16 9:34 PM
06/13/16 10:54 PM
Easy to mount would be a selling point for me.
DogoZX
DogoZX's Gravatar
06/14/16 8:24 AM
Usually is...
We still talking tires?
06/14/16 11:50 AM
If the thing that makes a tire hard to mount is the cable around the bead, I wonder how hard it could be to make this more flexible or to just not have it. One thing for sure, if you ride on a flat tire, bridgestone is the one to do it on. It sure won't come off.
DogoZX
DogoZX's Gravatar
06/14/16 1:05 PM
It's the tire's carcass that makes it more difficult... or easier for that matter.
Haven't messed with a set of Bridgestones in ages... but, talking about slicks, the Dunlops have a harder carsass than Pirellis... not sure if this carries over into their street dot lineup.
My team uses Dunlops for endurance (course we also ride a gixxer )... but I sprint race on Pirelli.
06/14/16 3:27 PM
Slick(s)? We talking about the Pirelli girl?
DogoZX
DogoZX's Gravatar
06/14/16 6:21 PM
We should be.
06/14/16 11:12 PM
Were we talking about slicks? Well that's what I'm going with on the 14. Supercorsa Pros. Red stripe. I suspec they are the same compound as the Supercorsa SP V2 with no sipes. Fast warm up, Cold track, extended use. Sounds like a street tire to me. We'll see. Also ordered a rear SP V2 for the busa. Sure liked them but didn't last long, of course. Wouldn't say they were easy to get on but the busa rim is not as conducive to tire irons as the 14 or Carrazeria.
* Last updated by: Rook on 6/14/2016 @ 11:13 PM *
DogoZX
DogoZX's Gravatar
06/15/16 10:24 AM
Or the Pirelli girl... at this point, I dunno either.
Then you best be headed to a trackday... or ten.
Tis how I understand it... Same compound, but will last longer... because that's what slicks do.
Had those on my r6 for a few track days and a few thousands street miles... Still have some life left. That's one thing I love about 600's... Guy can only eat so many potatoes.
06/16/16 11:35 PM
Don't I wish!! I'd need to have a windfall working part time at HDepot for the summer.
Man it sucks when you get this far and this happens. I managed to get the last bit over with a straight tire iron and a piece of plastic to protect the rim. Gotta remeber, always have a rim protector in place to get that last bite over the rim.
Also noticed this. Have to try sliding a piece of plastic over the top of the rim protector to cover the inside bead. Still seals fine but after 10 tire changes, I might start having trouble.
I checked runnouts and the wheels have a bit more than when brand new. No problem. Don't know what effect if any tire irons have. Might check again after the tire install. Weird thing is that the brake disks all have LESS runnout than when new.. One of the fronts was actually out of spec and now it's in spec! Strange.
* Last updated by: Rook on 6/16/2016 @ 11:39 PM *
06/16/16 11:43 PM
...and yeah, I think the Pirellis were easier than other tires I've done. Not EASY but easier. Front was not heated up in the sun and I still got it on with maybe a bit less effort than other tires. Both beads snapped in with only about 20psi. Didn't even need my special bead snapper chuck. Keep an eye out for my SLICKS FOR STREET TIRES thread. Will show pics of the Shiny new Diablo Superbike Pros.
Used the No-Mar grease! Nice stuff! Better than dish soap, should last a long time, probably worth the $16. Heck dish soap isn't free either and you need to use a lot. I din't use very much No-Mar grease. Wet it down after applaication and it's slicker than a greased weasel. STRETCHY fibrous goop....weird stuff but works nice!
* Last updated by: Rook on 6/16/2016 @ 11:51 PM *
DogoZX
DogoZX's Gravatar
06/17/16 10:33 AM
F that!... go break tires trackside!
What am I looking at? Those little scuffs? Those won't ever be an issue. I've seated beads on some nasty looking wheels. Spare rear (rain) wheel on my cbr looked like it had hopped a curb at 100mph... well it kinda did... but anyway, still held air same as the rest.
Keep an eye on that... and where the spokes meet the hoops. Have seen Tri R's come apart.
Bonus! Don't know the science, but seems logical (considering all the heat and pressure) those endure... Or maybe they're just floating on the bobbins?
I want pics of shagged Diablo Superbike Pros!
Slicks on a street bike will get noticed... just fyi.
I didn't like it... and always was worried a cop would come up behind me at a light, or wait for me in a lot, and just have nothing better to do than write me equipment violations.
Other than that though, just check the weather before going on any long rides. lol
Yes... a little goes a long way. I'm still using the original jar that came with my changer... use Astroglide more often though. j/k... mind on Pirelli girl still.
Oh... You gonna mount up a set of Rains on your factory wheels next?
* Last updated by: DogoZX on 6/17/2016 @ 10:35 AM *
DogoZX
DogoZX's Gravatar
06/17/16 10:44 AM
06/17/16 9:22 PM
Good to know. Thanks. Stil going to try to slide a milk bottle in there to avoid any contact. I guess I have heard of polishing the beads if they leak but sounds like I will be changing wheels before it ever gets to that point.
Yes they're light but those spokes are very thin. I imagine the potential for breakage may be the reason that they stopped making the Tri-R for the 14. Because of the many months it took my Tri-Rs to ship, I have this feeling I got one of the last sets that were ever made for the 14. Maybe the very last.
I thought they might have worn flatter. Never considered floating rotors. duh. I think these are semi floating? But they don't feel like they float at all when i press on them so IDK what they are.
If they are cheaper than street tires, maybe! The Superbike Pros were less than a set of Supercorsas and that was with a 200/55 tire instead of 190/55.
Actually having a set of normal, long wearing tires on the OEM rims would not be a bad idea. Only problem is I can't swap the sprocket between the CZ and the OEM. Sprocket changes = more wear on the drive. Oh well, there's never a perfect solution.
