Thank you Hub.YW
1st hand experience, just what I was looking for. Now, the next questions for you are:
1. What other changes did you observe when you did this change? I hear anecdotes like popping on decel. Decel is a given. When I rolled off, made that left, followed a car, said there is the pop? I added that second pipe= All stock with that minor left exhaust a touch open but my cats do not leave the building. Say the center cat was not there like it made a difference, remember I ran a few errands with that single pipe gave me less pop but it was there still. I wanna conclude I had less pop being what would be filled [on coast mind you] is a single pipe full of unspents not shared with the second stock pipe to lean me out.
I would have to re-install to a single pipe, hook a camera audio to the rear end, slow-mo maybe both single and dual, listen to both sounds off the left pipe and hear/feel the gargle loading the hacked pipe does to mid-cabling. You know that "mid" where the throttle is mid between throttling and not throttling = Mid Throttling?
Yeah, you should hear that puppy do the, 'mouth wash gargle.' And note for note she loads up (coded now being I have the '06 t-body in backup) all stock like piggyless/codes turned off, "Looking for Linear" sounding. I'm clicking your Youtube exhaust notes, [not yours of course, russty, is just say inn. Someone had the camera out of bike's physical range and all you hear is exhaust first. I said, oh that is some nice sounding tone there and he pans the rear end now. What tone do you think still has that certain note? He now moves and I see a set of stockers. He's bone stock. I have no clue if that was stock or he had a piggy sitting jetted in idle, I have no clue? Sure, you can change to any after market, we are going to be about the same in popping or more, it plays leanskis on lift, so if you wanna hear reference, I added for you when I heard a pop. Usually it is your concern about popping and I ignore you thinking you can quiet that popping bubble changing to hearing it more in a more open note to the air. It is popping in the stock pipes with the same lift at the throttle. You just do not hear it as pronounced. You wanna go nuts hearing that pop or depop your squidcity stopit all ready with the pop of nature farting out de ass. Nature lets your ass lift and pop is same-same out day exhaust is lie about everyday you pop piss tune don't give me that shit.
2. I recall you reinstalled the subs. Why?
I've been thinking that the purpose of the subs was to restrict the volume of air that can be inhaled. I then guessed that the ECU would reduce the amount of juice, to match the reduced air, coupled with a late detonation resulting in a 600cc torque curve until the ECU got the flies out of the way and lit up the fire works on time at about 3000rpm transforming sick litle sickle into fun beast. This is all post vino analysis (hic!) That first sentence said it all you walked to my same conclusion we are on the same page. The vino was added to your scenario in another post. I won't repeat the answer, being it is on another post in your thread somewhere else. I have to toast the real deal is she has no retard at the ignition [is for sure baby]! We are air guitar all the way. This think makes hey, I like your thinking and that is the deal is keep it a secret; like I can keep a secret open the book is tape it closed is so is my mouth.
Dis is wean-land all over again we are in OZ. Stop with the retard and that Ivan deal is gonna make you book smart and pop the fart on that lit'til sick'kill is not killing spark, it's killing the air. Now, think about that is how you gonna spark a retard at 3,000rpm? Are you thinking old style is now walk backward is where you came from before fuel injected acts the carb/ignition, we are same-same at 3,000rpm so say the advancer springs, you think advancer springs is walk air lag at 3k she opens wide the rpm revs up. Was the advancer before 3K at electronic spring tension or do the advance blocks return to static is balance the springs and weights to linear with air speed and you are locked no matter WOT.
Mess with my ignition at peak rpm or when the air speed matches advancer arms flinging out is she is locked and loaded. Can you imagine spark knock, detonation, rich fuel heat burning late down the cylinder wall is cook the water a lot faster you are out of that lean/lean is heat you mess with advance is 10° ATDC, you better have that gas burned, because the crank arm is lengthened so much is the fulcrum and all that physics is ideal fire is 10 degrees she is power stroke on the down stroke is pressure is all she wrote unless you piggy and add more burn what is lean by a tiny window.
Just for grins, I would install that advancer and work it up to 4°; see if asspucker can go to a certain on-ramp and puddle jump a cable full better than I had it hacked-tuned that day. Those were the subless-shaftless days. I am just as smooth. Only difference to me is as slight as the difference is, the difference is a flashing dash or a non-flashing dash I can live with the subeerear ass puck her toned down air sucker.
Take a study at the gear changes as the sub opens more. It's geared to give you premium performance and looking at that sub move me just banging down gear to rip it from first, you do not see that throttle bell housing move, but you sure see me gear down to first and the sub opens to the rpm. Show me ignition retard if the air guitar is moving I'm keeping time with my foot this thing makes; bee you tea full music.
Gonna drill this in you so you can seat of the pants the air and not advaNANanNaNaaaaaNa I told you not ignition, you stepped in it and eye present the 5 air guitars in 3 brands. You along with Chris Ulrich of RRWorld have an air issue if the OTTO-cycle runs like you installed a carb and a set of advancer springs. I am asking the question to you now: Would that run like the old bikes with electronic ignition, but the trick was first electronic, then evolved the advancer is way in the future is the tone ring count off the crank. No more advancer spring is there on the 14 or say, close to technical is 1999 or before, look for electronic with springs of old.
The advancer is on the electronic ignition, yes. The advancer on the bike 1999 is in the ECU making map. I have yet to figure out how to take those springs and remain linear in the ignition in the absolute way the bike fires off at 3K is full advance. I think I am going in the right direction if you and I both are up to that one sentence your assfigured out that assdata. Show me the money! Show me I am going to bog air or bog advancer springs?
Yes, russty, you are going to bog the advancer springs is look at that linear spring in the ignition advance and follow me pull your pop out of your ass is Ivan has your abstract is speaking out of his. Like, someone wean Chris Ulrich or show me that bike he was assfactor the data on. Myth my advance in the ECU or back-step in the evolution when the spring left the building give me air guitar that advanced tickets are sold out.
* Last updated by: Hub on 2/21/2009 @ 5:56 PM *
