Page: 1 2 3
Thread: Check their work! ... and Question
Created on: 11/16/15 09:52 AM
hagrid's Gravatar
RE: Check their work! ... and Question
11/18/15 7:09 PM
Every time you torque a fastener, you stretch it. The more times you stretch it, the longer it gets.
False.
If the specified torque value doesn't "stretch" the fastener beyond the elastic deformation range then no elongation occurs.
Yoshis!! GO NINJEE!!!
Danno's Gravatar
Southwestern Illinois
11/18/15 8:11 PM
Take it from Hagrid, not a whiskey-addled tire-slashing,lying asslicker.
hagrid's Gravatar
11/18/15 8:18 PM
See...
11/18/15 8:49 PM
Well...guess that 'bout sums it up.Use a TQ wrench to get it exact.Definitely can't go wrong there;)
I feel after a few of these bolts have been tightened..and IF a guy's paying attention...he can get it close by feeling the snugging and such.I've never been afraid to ride my bikes just tightening by feel.NOW...I wouldn't do it like this if I was working on a motor or something like that.
Something like front fork axle pinch bolts...you have the axle tightened for one thing.Then the pinch bolts...tightened according to the manual sequence.It'd be VERY unlikely for the axle to come loose with 4 bolts and a tight axle nut.You feel something wrong anyway if it did start to shift...the caliper and pads would begin to grip...or make noise.Not mention it wouldn't be feeling right in the steering.A spinning front wheel isn't gonna snap those calipers off there.That's my thoughts on it anyway.
I go for a ride(to wherever)...then back home...I sometimes check again just to be sure.But I've never had one back out...or loosen up.I do this with sprocket bolts...caliper bolts,pinch bolts.If I've changed discs,I recheck again after a ride.Never had any issues with those either.Shock...same thing.I check the link bolts and such periodically.Occasionally the lower fork tube pinch bolts.In 20 something K miles on my 14...I've never had any bolts work loose.And I've never used a TQ wrench on it.
* Last updated by: Grn14 on 11/18/2015 @ 9:09 PM *
Nastynotch
Nastynotch's Gravatar
11/19/15 6:37 PM
Either you're best friends, or there's an interesting story attached to that comment And you've all got it wrong. A bolt stretch gauge is the correct way, but not always possible to use. Carry on
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
Danno's Gravatar
11/20/15 3:57 AM
A bolt stretch gauge can only be used when said bolt is torqued to spec and you have clear access to both ends, such as with conrod bolts.
* Last updated by: Danno on 11/20/2015 @ 4:33 AM *
Nastynotch
11/20/15 5:58 AM
yes I know.
2013 ZX-14R SE
V1 custom mounted
pegscraper
11/20/15 12:02 PM
Saying a bolt will stretch when correctly tightened is misleading. A correctly tightened bolt will NOT stretch unless it is designed/made to be a 'stretch bolt'. Stretch bolts are torqued to a setting beyond the point of their elasticity and are usually 'once only' bolts requiring replacement after first use. Over tightening of the front axle pinch bolts would probably result in the stripping out of the thread in the alloy fork bottom before the bolts themselves stretched. A far as the rear axle nut goes, IME the slots in the castle nut rarely line up with the hole in the axle end when the nut is torqued to the exact torques setting in the manual which states that the nut should be tightened further if the slots in the nut do not line up with the hole.JMO
hagrid's Gravatar
11/20/15 12:41 PM
So, we are all in agreement: jimmymac'n'cheese is an anti-union, unemployable drunkard who excels at being misinformed.
11/20/15 1:06 PM
Used my new clicker type torque wrench last night to tighten / check all 4 of the pinch bolts. The right-side pinch bolt brother to the one that was about to fall out did need a little tightening, but wasn't close to falling out
Still don't have a 22mm hex socket, so have not been able to check the front axle's torque. "Seemed" tight, tho i.e. not about to fall off anyway.
I hadn't mentioned it so far, but during last Sun's ride (after which I found the loose bolt) was the first time I felt a little "sway" in the front end, while following my riding bud, in let's just call them 'high speed curves' on very remote county roads. Not a huge, bike upsetting feel like I was gonna be thrown, but enough that it caught my attention and caused me to let up just a skosh, and then resume the ride. Never had that happen in 5K miles with the OEM tires. I chalked it up to imperfections on the new PR4 GT tire(s) ...
What say you
* Last updated by: extrapolator on 11/20/2015 @ 4:27 PM *
Nastynotch
11/20/15 2:22 PM
All bolts stretch. If they didn't, they would never tighten. Torque-to-yield fasteners are one time use yes, but ALL bolts stretch.
2013 ZX-14R SE
V1 custom mounted
hagrid's Gravatar
11/20/15 3:33 PM
I think your brain has stretched.
11/20/15 3:59 PM
"I chalked it up to imperfections on the new PR4 GT tire(s) .."...sounds like it.How many miles on em?
11/20/15 4:10 PM
HaHaHa... love this forum.... almost three pages on torquing a bolt and when
all else fails sarcasms fly and everybody is an ass licker, hahaha....
Oh... I'm in the camp that all bolts stretch.
Also marking a bolt where it was before removing can be a valid aprx. torque setting
when reinstalling as long as you're sure it was torqued correctly when last installed.
I torque everything, every time, a lesson learned from my youth.
If I don't like the torque setting I'll loctite or safety wire it versus
adding a couple extra pounds.
Then again, I know for sure my brain is stretched.
11/20/15 4:26 PM
About 600 miles.
Nastynotch
11/20/15 6:33 PM
Would a bolt made from tungsten carbide tighten? I shouldn't have to explain this to someone like yourself.
* Last updated by: Nastynotch on 11/20/2015 @ 6:50 PM *
2013 ZX-14R SE
V1 custom mounted
hagrid's Gravatar
11/20/15 7:08 PM
*facepalm*
hu·mor
?(h)yo?om?r/
noun
1.
the quality of being amusing or comic, especially as expressed in literature or speech.
"his tales are full of humor"
synonyms: comedy, comical aspect, funny side, fun, amusement, funniness, hilarity, jocularity; More
2.
a mood or state of mind.
"her good humor vanished"
synonyms: mood, temper, disposition, temperament, nature, state of mind, frame of mind; spirits
"his good humor was infectious"
wfozx14
wfozx14's Gravatar
Upstate New York
11/20/15 7:30 PM
Take it from me, not a dumbass carpenter.
WTF kind of a comment is that jmac...I'm a carpenter who works on his own bike.
jimmymac
jimmymac's Gravatar
K.C. MO Northland
11/20/15 7:55 PM
There is a difference between a carpenter, and a dumbass.
Dan has really pretty and soft hands, and hasn't worked a hard day in his life. So calling him a carpenter was incorrect. He works with carpenters, but stays clean and doesn't lift a finger.
Bolts stretch. If you don't get that, use nails.
Let's roll
Nastynotch
11/20/15 10:47 PM
*facepalm*
hu·mor
?(h)yo?om?r/
noun
1.
2.
My humor detector and I are retiring for the evening. I kept the receipt, no worries.
2013 ZX-14R SE
V1 custom mounted
pegscraper
11/21/15 4:19 AM
[quote]All bolts stretch. If they didn't, they would never tighten. Torque-to-yield fasteners are one time use yes, but ALL bolts stretch.
/quote]
No. It's the friction between the threads that tighten and hold the bolt. That's why a bolt with bad or chewed threads feels tight. There's no way a M6 or M8 bolt tightened to 15lb/ft is going to stretch. JMO
Nastynotch
11/21/15 6:42 AM
*facepalm*
2013 ZX-14R SE
V1 custom mounted
Danno's Gravatar
11/21/15 7:00 AM
Dan has really pretty and soft hands, and hasn't worked a hard day in his life. So calling him a carpenter was incorrect. He works with carpenters, but stays clean and doesn't lift a finger.-jiffylubemac
Another jimmielie. I worked with my tools for over 30 years-framing, roofing, concrete, piledriving, drywall, metal studs, not to mention casework, cabinetry and even a little millwright work ovehauling gas turbines. Unlike him who does an oil change on a semi-truck and washes his hands three times in the process, I was working for a living and raising a family while he was still stealing cars with his junior-high school delinquent friends. Some things never change.
Crawl back in the bottle, little man. It's the only place you're safe from reality.
11/21/15 7:20 AM
We're finally startin' to get a little of that good ol' fashioned thread jack up in here!
Carry on ...
hagrid's Gravatar
11/21/15 7:38 AM
I just hope Danno doesn't find out what jmac'n'cheese said about his wife cuz the fur would fucking fly for sure.
Page: 1 2 3
