Rook, is it the syn or do we drop the sump. Is it a shifting habit that killed the clutch in both bikes?
I'm voting for "shifting habit." There was never a drop of synthetic in the Vukcan. As far as drop the sump, I still have to finish my 500 "hope it just goes away" miles.
I can see the double shifting of a car/truck, but a bike's trans does not have huge gears but smaller and more of them. No fault to dad or you.
HAHA...that's quite a memory you have, Hub! You recall my stories of Dad teaching me to drive a truck! Yes, even recommended double clutching between upshifts which was really just a timing thing as far as I could tell. Same thing as holding the pedal down one time twice as long. Oddly enough, he also showed me clutchless shifting too but those old Ford twin axles didn't like that too much unless you hit it just right. If you remeber my track vids, you probably see I ride like I'm driving a truck!
If I stop adding throttle spin I stop a wearing down of plate, this causing added friction that does absolutely nothing but wears parts out faster. The 800 and 14 are 2 examples.
Man Hub, doe you have a crystal ball? You know just how I shift. Yes, I do detect the motor spin up faster when pulling the clutch and rolling back on the throttle...not always but pretty often.
Are we on the same page?
Almost, Hub. It's this close (my finger and thumb are very close together). ...but i know you are an OEM guy so goes the bias to OEM parts. I'm inclined to believe you on this one though. Have to check other opinions. ALready heard OEM is the way to go with clutches from one other person.
Hey Rook, I want one of them Evo shift stars.
Never heard a complaint about them, Everyone seems to like them. Grn said it felt like the throw in the shift lever was shorter. I don't know if he liked it enough to get one for the 14r. BG really liked it in his 14. He gave it high praises. If I replace the clutch, I might as well do the star too igf I can swing the doe. Another 200 smackers in the beast.
wait until till the bike has over 2500 miles on it,then do the full synthetic oil change because of any chance of a clutch issues..if anybody has a commit on what I have posted please do so..
Thanks MRZX
Wait till AT LEAST 2500, that's what I've always heard too, MR. In fact, if I were you, I'd set that synthetic aside until 5000. IDK if matters as much as most people say but to me, it's not worth the anxiety. I still have my busa on dino oil and I'm not in such a hurry to switch. Change the conventional more often and I think that is just about as good as using synthetic. Dino oil is pretty smooth when new, if you ask me.
Other side of the coin is that sythetic stays so clean, it may actually clear away tiny deposits that are actually sealing your engine. The theory is that if you wait too long your engine starts to seal up the tiny gaps with crud left behind from dino oil. The synthetic dissolves the crud and you have potential openings that oil can seep through. Once it finds a path under a gasket, its awful hard to stop it up. This, I believe. My head cover leak developed after I started using Rotella synthetic. That is all fixed up now. I still use Rotela Synthetic. Don't let it worry too much. Eventually, all engines will leak any kind of oil you put in it. If it's gonna leak, it will probably leak faster with synthetic. You gotta use some kind of oil so just take heed of all you hear and do what your heart tells ya. Just like break in procedures, do what you feel is best. No one knows for sure.
Get the brocks clutch mod in there - that'll stiffen things up..... soon you'll have forearms like popeye...
The springs? Yes I heard the high tension springs are a good piece. Kruz used them in his ZX-10 and he said they did not make the clutch too much harder. Oh yeah, but
he already has forarms like Pop-eye!
toot-toot
* Last updated by: Rook on 4/15/2014 @ 11:07 PM *
