"As far as losing TC... ... but the gen4 10r uses the secondaries as part of the TC system. If you remove them from that bike, you lose TC... I'm assuming the 14r is the same".
Well...he didn't say IF he had his bike in the Ktrc engaged mode.So who knows.I would think the Ktrc would still work...I'm guessing here that the plate position is being 'set' by the ECU and throttle position,not fuel/air mix.This deal is supposed to be intuitive...responding to wheel spin ,front and back.Not sure the secondaries actually have a real role in the punch factor.The ignition gets adjusted for stopping wheel spin...from what I read.Naturally,the secondaries would be somewhat affecting the whole process(which is in microseconds)..but to what extent...I wouldn't know.
You know...you're rolling on in a wheelie,lofting,then the front wheel begins to slow..and the Ktrc kicks in causing the front to drop and both wheels to be rotating again at the same speed.Is that secondaries?It sounded like ignition to me in that one vid of that guy on the zx10R.He was keeping the throttle(plates)wide open.But the motor was being adjusted to stop the wheelie from going any further.When he had both wheels back on the ground,the engine kicked in again with the flies and all wide open.And away he went...happy as a clam.
I'm guessing if you have the Ktrc turned off,then the bike is gonna perform like a stock 14...so if she starts lofting,she's gonna go to the 12:00 real quick,and beyond if yer not real careful.Flies or no flies.??????Without that wheel spin(front/back)input...it just thinks it's a "normal' bike.That's what I'm guessing.I think taking the flies out will enhance an already kick azz motor.I don't think it's gonna cause any problems with the Ktrc turned on.If it detects wheel spin,it's gonna adjust no matter WHAT the engine speed or velocity.????I'm not sure if I understood Kawasaki's explanation of the secondaries role in the whole process...even though it was mentioned.The focus of the thing seemed to be on the ignition timing being the main way that the Ktrc operated.I think(if this is correct)the secondaries were being adjusted during this ignition adjustment for 'smoothness' of engine performance.Okay....to me that says....the secondaries are a 'buffer' for the kick or whatever.Removing those will most likely give the whole deal more of an "edge' I would think.You know....what Kawasaki thinks of as smoothness...is probably different than what we here really want...quick hard throttle response.You removed those flies in the earlier models...what happened?Better throttle response,and more of an 'edge'.I think it's the same here.No matter what...you turn off that Ktrc,yer gonna get wheelspin.
* Last updated by: Grn14 on 12/2/2011 @ 12:17 PM *
