I knew that, Wolfy. I just knew also; I'm going to die broke buying bikes so I broke it in hard and compression may have been high, but the bike burned oil between changes and that was averaged out to 2.7k. Broke the last bike in by the book, never topped the bike off between changes. And I'm sure if I feel the trans shift shitty, the oil is dumped on say that same average of 3k give or take. Same high compression found in the tighter sealed surface of the book-broke.
Saw an up-close camera aimed at a lathe cutting bit. I watched how it sheered the metal off like if you saw a mudslide, that's the way the metal was leaving; as if a bulldozer with a sharp blade was cutting into the ground and shaving fresh sod from a farm field.
If you were ever around a bulldozer, see how that mud is not mud, but enough to see a smooth finish in the semi-wet dirt, you see the edges raised, and then these tiny gaps are left? Imagine the same exact finish on that metal the micro-cam was exposing. Dirt for dirt, metal sheer for metal sheer, you could see the same smooth/rise/craters both blades made as if they were twins.
Recently watched a plasma coating gun drop a constant feed of metal chips or balls(?) into the back of the flame. This then heats and melts from solids into a liquid state. Imagine rolling up clay or dough and slam it against the wall. You now take millions of those micro balls and they melt and splatter over the clay/dough next to it and then a 3rd falls in the middle of the 2 molten balls. So imagine the pattern of the coating and the melted balls having a high round, smooth ridge, but leave craters between splats of the balls hitting and melting semi-flat.
Sharp ridges bulldozed into the cast iron finish to now, a semi-high melted ball as if there were balls of speed bumps or more like an old cobblestone street surface is more the nikasil finish. Look how long it is going to take to create a better seal between shaving the cobblestone street finish down. Look at how the crosshatch is still there after miles of wear. The ring begins to gap before the wall finish is removed.
I doubt I would hurt the finish. It's the rings I would change after hard break-in or slow tfd ffs! Da f is it wit chew guys! F'inn motoshitface is ruined my ring face of all faces I meet up wit chew again!?
