Sorry, Still no final numbers only one roller is hooked up, so power is reading way wrong, I was only hitting like 175whp LOL the bike before me should be doing about 180 or so, was barley doing 100 LOL, but I did get it back after Jerry went over it again top to bottom, and I took out the 5.8psi spring, and put in the 8.5psi wastegate spring, I also took out the +1 front sprocket, and put the stock front sprocket back in as well. Then Jerry had it on the dyno just doing pulls with the wideband to clean up the tune a little further, Lets just say, its a whole new bike compared to a couple weeks ago.
Only current issue, If you take the filter off, and power goes way up, so before he spent a ton of time further on the tune. Since filter size is making such a huge difference on the tune, I ordered a bigger filter, instead of 3inch diameter and 5inchs long, its 4.5base tapering to 4 and still 5inchs long, and the top is also filtered instead of capped off. My rough online surface area calculators show this is roughly a 45% increase in surface area, so once it shows up, and his dyno is completely done being setup, ill go back for final numbers.
I also got pricing from a couple places on doing a full new swingarm. Will probably go 1-2 inchs shorter than what I am right now with extensions, nothing major. Right now my extensions max out at 9over, and im almost all the way out, and the arm ill order will max out at 8, and I plan to set it around 7over. I will probably order a new arm over the next couple weeks or so. Not a huge rush, but its the last part on the build I want to do. Everything else id like to do can wait until winter. New rotors, new pads, steel braided lines, and so on.
Old Filter:
New filter I just ordered:
2007 Plasma Blue ZX-14.
